How to search for just part of FME Feature attribute name?
  • December 12, 2016
  • 28 views
I have exposed the fme_feature_type attribute.
I am then using the FeatureWriter to write this feature class (FGDB) to POSTGIS.
Its new name in POSTGIS is @LowerCase(@Value(fme_feature_type))_load.
My next transformer is the SQLExecutor where I am trying to find if the above table already exists but doesn't have the _load at the end and DROP that table if it does exist
So for example. I am loading Cities_load but want to drop the existing Cities table if it exists and then RENAME the Cities_load to Cities.
What would my SQLExecutor read?
DROP TABLE IF EXISTS @ReplaceString(@Value(_feature_type{0}.name), '_load', ''); ALTER TABLE @Value(_feature_type{0}.name) RENAME TO @ReplaceString(@Value(_feature_type{0}.name), '_load', '');
The above SQL doesn't seem to work correctly...
erik_jan
Forum|alt.badge.img+26
  • December 12, 2016
I would create a new attribute (DROP_TABLE), copy the value of fme_feature_type in that attribute and then use the StringReplacer to replace "_load" with nothing. Then use that attribute in the SQL statement avoiding the functions in the statement.
erik_jan
  • December 12, 2016
Or use the SubstringExtractor as shown in the image (replace Test_load with attribute containing table name and result attribute to be DROP_TABLE):
  • December 12, 2016
@erik_jan, I can tell that the correct renaming is occurring by looking at the logfile. Thanks for the SubStringExtractor tip.
but I am still getting this error.
Error executing SQL command ('ALTER TABLE energy_land_northamerica.cities_load
RENAME TO energy_land_northamerica.cities'): 'ERROR: syntax error at or near "."
LINE 2: RENAME TO energy_land_northamerica.cities...
