how to reduce the amount of las tiles for a given area?
  • Dec 21, 2018 10:22 AM UTC
  • 50 views
I have 2234 las datasets covering around 2000 km². I want to reduce the amount of tiles by 1/8 thus increasing the area per tiles by 64.
Which workflow could I use to merge neighbouring tiles without overlaps?
itsmatt
Forum|alt.badge.img+48
  • Dec 21, 2018 10:36 AM UTC
PointCloudCombiner is your friend here - if you can work out a nice way to assign new groups (perhaps based on the file names?) then you can use the PointCloudCombiner with the Group By set to your new Tile_name.
A good way with tiles is to try and map the filenames to a bounding box which can be helpful.
Another approach might be to read everything into a Tiler transformer, however, I would try and avoid that as I expect it could take a while to clip everything.
2DGridCreator, BoundingBoxAccumulator are both tools which you might find helpful
It does not have to be 8 -if it is easier mathematically 9 or 12 would also work.
