How to read .xyz file and write points (x,y) with text z-value etc.
  • Dec 5, 2012 9:08 AM UTC
  • 15 replies
  • 356 views
jopie
Participant
Forum|alt.badge.img+3
I'm trying with the workbench to create a new file.
I want to read a .xyz file. And want to write to a other file (shp, dwg or oracle spatial etc.) and use it in a GIS system.
There are many points (to many) i want to display those points on a distance of 100meters and only inside our city borders.
Result must be all points (raster 100m) with a text z-value in our city
I h've: .xyz file and an oracle spatial of our cityborders
It's clear , i'm a beginner can someone put me on the road to solve this question?
greatings,
jopie
sigtill
Forum|alt.badge.img+25
  • Dec 5, 2012 9:26 AM UTC
Some hints
1. Read the xyz file with a Textfilereader.
2. Create points for each file using a 3DPointReplacer
3. Load the file with city borders
4. Use a Clipper to clip points inside the city borders.
After that use the  TextStroker on the z-value, ImageRasterizer and a rasterwriter.
Gives you some hints, but not the complete solution :)
fmelizard
Forum|alt.badge.img+22
  • Dec 5, 2012 9:27 AM UTC
Read the XYZ points, coerce them into points and clip them to the city boundry.
I dont really understand what you mean by 'those points on a distance of 100m" can you clarify?
fmelizard
  • Dec 5, 2012 9:28 AM UTC
I would use the Point Cloud XYZ reader instead much faster.
jopie
Participant
  • Participant
  • Dec 5, 2012 3:08 PM UTC
Hi,  Itay and SIgTill
Itay:
It's not working. ill think i'm doing something wrong
Boundary = .shp and  coord = .xyz
pointcloudcoercer just and then clipper and then a inspector. nothing written.
What's wrong? parameters clipper???
a line in the logfile gives this:
Clipper_Solid(SolidIntersectionFactory): No clipper supplied, all clipees will be treated as OUTSIDE
Sigtill:
text reader csv x,y,z, 3dpointreplacer, shp boundary and then clipper. shp to clipper and point to clippee. Ispector to clipp..inside.
It's not working what's wrong
Greatings,
Jopie
sigtill
  • Dec 5, 2012 4:59 PM UTC
Clipper: Needs a Clipper AREA as input (make sure your CITY BORDERS are AREA and not only LINES, if they are LINES you should build an AREA of them before sending them to the clipper)
Make sure both CITY BORDERS and POINTS are in the same coordinate system.
Can you provide a SMALL sample containing SOME points and the CITY BORDERS file? (for instance upload it to www.filemail.com and paste the link here).
jopie
Participant
  • Participant
  • Dec 6, 2012 7:49 AM UTC
I've uplaod some files . Maybe thay tell you more. Thanks.
jopie
Link to download page: https://www.filemail.com/dl.aspx?id=ARGTDEEAULUKRUJ
jopie
Participant
  • Participant
  • Dec 6, 2012 7:51 AM UTC
Sorry:
Go to http://www.filemail.com/dl.aspx?id=ARGTDEEAULUKRUJ to download the files.
fmelizard
  • Dec 6, 2012 9:08 AM UTC
The boundry file supplied is not good, can you upload a new one?
Also the point file has the same Y values for all the points.
You can change the extention from csv to xyz and use the XYZ reader, much better performance.
Also extract the bounding box coordinates of the boundry and appliy that in the XYZ reader to minimize the amount of data.
jopie
Participant
  • Participant
  • Dec 6, 2012 9:46 AM UTC
Hoi Itay,
Here are the new files. Youre right file was wrong.
Go to http://www.filemail.com/dl.aspx?id=HRGBJIQTJJYNAOB to download the files.
Thanks.
jopie
jopie
Participant
  • Participant
  • Dec 6, 2012 9:48 AM UTC
sigtill
  • Dec 6, 2012 7:11 PM UTC
Hi Jopie
I have sent you an e-mail with a suggested workspace. Just replace the inputfile with your file.
jopie
Participant
  • Participant
  • Dec 7, 2012 7:53 AM UTC
Hoi Sig Till,
Thanks, but i've got any email from you yet.
This email isn't large, i surpose?
Is it less than 8 Mb? More will be blocked by provider.
Greatings,
jopie
sigtill
  • Dec 7, 2012 12:48 PM UTC
Nope, quite small actually. E-mail is: jmegens@westmaasenwaal.nl ?
jopie
Participant
  • Participant
  • Dec 10, 2012 7:17 AM UTC
yes
sigtill
  • Dec 12, 2012 8:18 AM UTC
Sent you a new e-mail
