How to read texts from dwg file which is associated with SHX font
  • Apr 17, 2018 2:43 PM UTC
  • 9 replies
  • 299 views
I am having a large set of DWG files in which all the texts are referenced to a native Autocad font file called XARB.SHX, when I try to read it through FME desktop the fme_text_string shows something which is unrecognizable as FME is referring windows fonts.
I am unable to read the autocad (XARB) style applied to the text in dwg file.
It will be very helpful If anyone can suggest me some workaround.
Thanks in advance.
IMRAN
danilo_fme
Forum|alt.badge.img+58
  • Apr 17, 2018 3:05 PM UTC
Hi @imran
Did you try to enable some configuration in Parameters from Reader DWG?
Thanks,
Danilo
jneujens
  • Apr 17, 2018 3:06 PM UTC
Could you share an example of a .shx file?
  • Apr 18, 2018 6:00 AM UTC
Shared the dwg file and font (style) file in Zip
  • Apr 18, 2018 6:01 AM UTC
Hi @imran
Thanks,
Danilo
Hi Danilo,
Enabled and checked with everything but nothing worked
danilo_fme
  • Apr 18, 2018 12:03 PM UTC
Hi Danilo,
Hi @imran
Could share us the file?
Thanks!
  • Apr 19, 2018 11:00 AM UTC
Hi @imran
Thanks!
text.dwgxarb.zip
Sharing the DWG file and font (style) file in zip
  • Sep 20, 2022 10:00 AM UTC
I think this issue still not fixed. Also I need a solution for this subject.
JennaKAtSafe
Forum|alt.badge.img+9
Hi @Ömer Seyfettin KAR​, hopefully Andrea's comments on this thread can serve as a workaround
omerseyfettin
Hi everyone You can find attached fmx Transformer which convert the most famous Arabic XARAB.SHX and Y-ARAB-1B.SHX fonts to UTF-8 unicode.
