How to read multiple csv with dynamic URL ?
  • Nov 12, 2019 9:35 AM UTC
  • 98 views
Hello I have a problem,
I try to read multiple csv from an URL that changes.
An exemple of URL :
I tried to use an HTTPCaller and it works but I don't know how to treat the result. I don't find any transformer that can help me to translate this string "csv" into a list of attribute.
If someone can help me it could be great please.
Here are two images of what I get with httpcaller :
Forum|alt.badge.img+54
  • Nov 12, 2019 9:39 AM UTC
You can use the httpcaller to save the response to a file(s) and then use a featurereader to read the csv file(s) back in.
Mmh it could work but I save all the csv into one file ?
  • Nov 12, 2019 9:58 AM UTC
I'd save to multiple files, they can always be deleted later. The other option is to use an attribute exploder to split by line, followed by another attribute exploder to split at the semi colon, then rename the resulting list elements as per the csv structure.
Ok actually your first answer worked pretty well. Thank you very much !
