How to read DWG file in FME with attributes data
  • November 14, 2022
  • 16 views
timnil00
Forum|alt.badge.img+5
Hi!
Im having a struggle to merge the "objec data" to the "block" or the actuall autocad_ellipse.
When i zoom to line 1 it contains no geomtery, how can i add the object data to the ellipse (line3)?
 2022-11-14_12-41-25
2022-11-14_12-34-12
danilo_fme
Forum|alt.badge.img+45
  • November 14, 2022
Hi @timnil00​
Did you expose the autocad attributes in Reader?
Please, could you share your sample data?
Thanks in Advance,
Danilo
timnil00
  • November 14, 2022
Hello!
No i do not, i’ve just put a ”AttributeExposer” transformer after the reader.
sure ill fix tomorrow when im back at work :)
timnil00
  • November 15, 2022
Here are my files. I have now tried to expose the attr_ in the reader but still its not in the ellipse.
danilo_fme
  • November 15, 2022
Thanks your Workspace and file. I tested internally here and the best solution is merge both information with FeatureMerger.
Thanks,
Danilo
