How to query all add/delete tables in SDE and have a count of each as a row in the output
  • Apr 18, 2024 8:26 PM UTC
  • 10 replies
  • 180 views
schulte.a
Forum|alt.badge.img+4
Hello, I am trying to create a workbench that will read in all our add/delete tables from our SDE, do a count on the running total of records for each, and export a spreadsheet with the table name, and the counts in each,
I’m using a SQL Creator and my SQL statement is something like SELECT COUNT(*) FROM <tablename>,and right now that's not returning me any value even though it was successful? Also, how would I go about coding out to add the next table in?
would it be:
union
SELECT COUNT(*) FROM <tablename2>
union
and so forth?
also for background:
We use Microsoft SQL Studio, and I chose the connection as a spatial server.
Thanks for any help!
Best answer by nielsgerrits
Can you show your SQL? The alias might need to be written in quotes.
SELECT COUNT(*) AS “totalRecords” FROM @Value(tableName)
I rarely use this nowadays so it is a bit dusty, sorry.
nielsgerrits
Forum|alt.badge.img+67
You probably want to use an alias, like
SELECT COUNT(*) AS totalRecords FROM <tablename>
and then expose totalRecords.
Not sure about the union part, I think I would send one feature for each query, with the tableName as an attribute so you get something like
SELECT COUNT(*) AS totalRecords FROM @Value(tableName)
This way you will get a feature for each table with tableName and totalRecords, which can be directly written to excel.
schulte.a
  • Apr 19, 2024 1:41 PM UTC
Hmm, tried that and it’s a successful query, but the output is blank.
nielsgerrits
I suspect the result is there but unexposed. If you select the record in the visual preview or in the Data Inspector, activate the Feature Information window and select the record. Then you will see everything about the feature on the right side of the screen.
schulte.a
  • Apr 19, 2024 1:48 PM UTC
Ah yes, I do see that its not exposed, but the property & data type columns are blank, but the value is correct.
nielsgerrits
Can you printscreen what you see?
schulte.a
  • Apr 19, 2024 1:52 PM UTC
nielsgerrits
If you click on the arrow with unexposed attributes, you should be able to see the unexposed attribute names.
nielsgerrits
  • Apr 19, 2024 1:54 PM UTC
schulte.a
  • Apr 19, 2024 2:11 PM UTC
That worked! Thank you so much!
nielsgerrits
Cheers!
