How to order the objetcs of different layer with a dwg writer?
  • May 29, 2019 7:12 PM UTC
  • 6 replies
  • 113 views
bernarddinon
Participant
Hello,
I want to write a dwg with several layer. In layer i can have block, points or Text. How can i do to order the objects in a systemaic way?
Bernard Dinon
Best answer by takashi
If you need to sort the features based on some criteria, the Sorter transformer might help you.
danilo_fme
Forum|alt.badge.img+58
  • May 29, 2019 7:51 PM UTC
Hi @bernarddinon
There are two options : Order Writers by in Navigator -> Workspace Parameters -> Translation ->
Thanks,
Danilo
bernarddinon
Participant
  • Participant
  • May 29, 2019 9:47 PM UTC
Hi @danilo_fme. I will try it tomorrow. Thanks for the answer. I'm will tell you if it's works like i want.
Bernard
danilo_fme
  • May 30, 2019 11:57 AM UTC
Bernard
Excellent @bernarddinon
bernarddinon
Participant
  • Participant
  • May 30, 2019 5:42 PM UTC
Hi @bernarddinon
Thanks,
Danilo
Hello, It doesn't work because i have only one dwg writer with several layer
  • May 30, 2019 11:13 PM UTC
bernarddinon
Participant
  • Participant
  • May 31, 2019 8:28 PM UTC
Thank You Takashi. It work with a sort order by descending Numeric :)
