How to merge 2 PDF to multi page PDF
  • Jun 7, 2019 1:57 PM UTC
  • 144 views
Hello everyone
I have a directory of PDF files and would like to select some of them for merging.
Is there a way of merging a list of PDF files to a multi-page PDF file?
Thanks.
jovitaatsafe
Forum|alt.badge.img+11
Hi @shadowgun3108,
I noticed a similar question in our Forums that has some useful answers. Please take a look at Holly's suggestion here and if you are having any trouble reading in your whole pdf, perhaps Xiaomeng's method may work better for you.
chrisatsafe
Hi @shadowgun3108,
You can write multi-page PDF's by using the PDFPageFormatter transformer and setting the page number attribute. Please note: "a single PDFPageFormatter transformer is intended to format one page of a PDF document. Using multiple PDFPageFormatter transformers will allow writing to the same PDF document."
This will make your workspace look something like this.
Alternatively, you can write multiple pages using a single PDFPageFormatter by overwriting the pdf_page_nmber format attribute as mentioned in this thread or the PDFMultipageSet transformer from the FME Hub!
Hope this helps!
