Best Answer
How to intercepte verify if shp file is empty?
  • January 9, 2018
  • 16 views
farfar
Forum|alt.badge.img+12
Hello,
My fmw used a shp file reader. If this file is empty, ican't get error.
Have you any idea to intercept that the file is empty?
Thanks an advance.
Best answer by david_r
One solution could be to use the NoFeaturesTester from the FME Hub.
  • January 9, 2018
farfar
  • January 9, 2018
Thanks David
