How to import active directory user as FME server users in FME server 2019
nag
Hello Team,
We recently upgraded FME Server 2019, and tried create AD group user it was asking for Search Account Password which i am not very clear about it.
Can somebody instruct me how to export AD group users into FME server 2019? Is there any prerequisites to do this activity? What is the process to add AD group user to FME Server.
Thanks in advance.
Best answer by sigtill
Hi @nag
I recently did the same. Don`t know much about the AD, but had a screenshare with a very experienced IT-guy so he could help putting the right settings. He also had to do something "backend" for it to work. So if possible I would contact IT directly and let him set up together with you.
Then he can also help setting up the Notification settings and also if possible an account for e-mail so fmeserver can RECEIVE and send e-mail.
Good luck - AD is a bit hassly to setup, but it is worth it for the users NOT to remember a new password and helps onboarding alot!
sigtill
Forum|alt.badge.img+24
  • January 29, 2020
Hi @nag
nag
  • January 29, 2020
sigtill wrote:
Hi @nag
Thank you very much sigtill for your support.
nag
  • February 18, 2020
sigtill wrote:
Hi @nag
Hi @sigtill
Did you get any chance to contact IT guy, Regarding above context.
sigtill
  • February 18, 2020
nag wrote:
Hi @sigtill
Hi @nag - sorry for being unclear with my text. By writing
"So if possible I would contact IT directly and let him set up together with you. "
I actually ment that you had to contact your IT-directly :/ - sorry for the confusion.
