How to ignore errors in RCaller
  • October 25, 2024
  • 5 replies
  • 72 views
mr_fme
Forum|alt.badge.img+9
I have one script in R running in RCaller, but the RCaller show some messages like erros but no erros, my script run properly.
I would like to ignore these messages and generate one feature for the next transformer. How can I do this?
Thank´s
Best answer by hkingsbury
As i mentioned, i’m no R expert, but the above looks fine.
It’s quiet difficult to debug without being able to see the full log and script.
Might be best to open a support ticket with your reseller where you can share that level of information with them.
hkingsbury
Forum|alt.badge.img+55
  • October 28, 2024
Depending on how the RCaller is ‘failing’ I can think of two approaches (FYI i’ve never used R).
  1. If the RCaller is not outputing a feature because it doesn’t return a feature to trigger the rest of the workspace, you could put a NoFeatureTester after it and this will create a feature if none are recieved.
  2. If the RCaller is failing and is therefore causing the workspace to fail, you could look to use the tryCatch() function - https://stackoverflow.com/questions/12193779/how-to-use-the-trycatch-function
mr_fme
  • October 29, 2024
Hi @hkingsbury
I tried your options, but unsuccess.
No FeatureTester no show features after erro in RCaller.
Try Catch too...no work properly. Shows errors in RCaller.
Thank you
hkingsbury
  • October 29, 2024
Can you share how you’ve implemented the tryCatch() in you code?
The purpose of try-catch functions are to gracefully catch errors allowing processes to properly manage them with out failing
mr_fme
  • November 1, 2024
@hkingsbury,
Unfortunately I can´t send the code, but my implemantation is like below:
 tryCatch(
            # Just to highlight: if you want to use more than one
            # R expression in the "try" part then you'll have to
            # use curly brackets.
            # 'tryCatch()' will return the last evaluated expression
            # in case the "try" part was completed successfully
            message("This is the 'try' part")
            suppressWarnings(readLines(url))
            # The return value of `readLines()` is the actual value
            # that will be returned in case there is no condition
            # (e.g. warning or error).
        error = function(cond) {
            message(paste("URL does not seem to exist:", url))
            message("Here's the original error message:")
            message(conditionMessage(cond))
            # Choose a return value in case of error
            NA
        warning = function(cond) {
            message(paste("URL caused a warning:", url))
            message("Here's the original warning message:")
            # Choose a return value in case of warning
            NULL
        finally = {
            # NOTE:
            # Here goes everything that should be executed at the end,
            # regardless of success or error.
            # If you want more than one expression to be executed, then you
            # need to wrap them in curly brackets ({...}); otherwise you could
            # just have written 'finally = <expression>'
            message(paste("Processed URL:", url))
            message("Some other message at the end")
hkingsbury
  • November 3, 2024
