How to get georeference for objects placed on Autocad paper space? Any parameter or format attributes?
  • January 13, 2016
  • 7 replies
  • 56 views
arekpierchala
Hi
I've got ACAD file and need to migrate objects placed by operator on autocad paper space. FME can read paper spaces (parameter 'Read Paper Space') but objects have got coordinates related to paper spaces. Is there something to get georelation for paper space and map data?
daveatsafe
Forum|alt.badge.img+20
  • January 13, 2016
This is possible, although it is a little complicated and requires using FME 2016 beta. There are now viewport features in the paper space, which have a polygon geometry and attributes for the model space extents they cover.
- Use a PointOnAreaOverlayer or LineOnAreaOverlayer to transfer the viewport attributes to the paper space features within them, grouping by autocad_space.
- Use an Offsetter to offset the features by the negative of autocad_viewport_center_point_x and autocad_viewport_center_point_y.
- Use a Scaler to scale the features by the inverse of autocad_viewport_custom_scale.
- Use another Offsetter to offset the features by autocad_viewport_view_center_x and autocad_viewport_view_center_y
This process will work for simple top down viewports with no perspective.
arekpierchala
  • January 14, 2016
Thanks a lot. It works in FME2016beta.
arekpierchala
  • January 19, 2016
For full success for my data I've used additionaly Rotator (360-@Value(autocad_viewport_twist_angle)) before first offsetter and Offsetrer(autocad_viewport_resolved_target_x and y)) instead of autocad_viewport_view_center_ parameters
deanhowell
Forum|alt.badge.img+24
  • November 26, 2019
Hello @daveatsafe this is exactly what I am trying to do so was wondering if you have any examples you could provide to show how the above is done.
deanhowell
  • November 26, 2019
Hello @arekpierchala, I know it was a while ago but just wondering if you might be able to share the workspace fundamentals on how you achieved the above as I am trying to do the same.
deanhowell
  • November 26, 2019
Here is what I did based on the instructions from @daveatsafe above. Thanks :)
gisbradokla
Forum|alt.badge.img+17
  • December 15, 2023
Or use the chspace command in autocad
