How to force output feature to get name from feature type name property rather than the file name that a writer initially requires?
  • May 8, 2014 7:17 PM UTC
  • 5 replies
  • 72 views
makt
I noticed today that the dwg writer asks for a file name in a folder (unlike other writers that simply ask for a folder).
How can I force FME to call the resulting dwg by  the "feature type name" that I define in the name parameters of the writer? It seems that when I do define a name here, it still reverts to calling the output whatever I chose when I was first forced to chose a folder and file name of the writer.
Best answer by david_r
have you tried using a Dataset Fanout (http://docs.safe.com/fme/html/FME_Workbench/Default.htm#Setting_Dataset_Fanout_Properties.htm)?
David
  • May 9, 2014 7:26 AM UTC
gio
Forum|alt.badge.img+15
  • May 9, 2014 1:16 PM UTC
Featuretypename results in a autocadlayers in the dataset.
Datasetname would be the autocad file (dwg)
To do that u need ot use the Datasetfanout. Rightclick on the autocadwritername in the navigatorpane. Choose fanoutdataset...
set to yes, and fill out the parameters.
makt
  • May 9, 2014 8:28 PM UTC
Thanks David, Gio.
What is the reasoning for this added bit of complexity?
In other words, why the inconsistency between writers?
  • May 10, 2014 1:58 AM UTC
There are two types of file-based data formats. 1) A file can contain only one feature type, e.g. SHP. 2) A file can contain multiple feature types (layers, tables ...), e.g. DWG.
Dataset conceptually is a data set of multiple feature types, so it will be: a folder for the 1st type; a file for the 2nd type.  I think there is no inconsistency ;)
makt
  • May 12, 2014 5:44 PM UTC
takashi - indeed that explains the why! thanks
