How to flatten a multi-record tab table into a single record Excel table...and some stats?
  • Apr 3, 2018 3:09 PM UTC
  • 207 views
Hi all.
I've got a tab file that I run a few queries against it to pull out some values which based on a published parameter used for the query. The results are then written into an Excel table
In this case the publish parameter ‘LEASE NAME’ used in the query has extracted the Collingwood 3 data from dataset. Seven records were extracted however I’d like to make those into a single record that contains data from each attribute where present. Additional I want to sum the values in the length columns.
At the moment it looks like this.
But I want it to look like this.
What should I be doing to get this result?
Thanks a heap
Michael
Best answer by takashi
Remove (i.e. Map to Missing) all the Empty and Null attributes with the NullAttributeMapper, and aggregate the records with the Aggregator transformer.
  • Group By: LEASE NAME
  • Accumulation Mode: Merge Incoming Attributes
  • Attributes to Sum: length
Then, create a published parameter from the Group By parameter in the Aggregator.
  • Apr 3, 2018 4:07 PM UTC
  • Apr 3, 2018 10:53 PM UTC
Hi Takashi. That looks to have worked. I'll do some testing on other values but it's now coming out as a single record. Thanks, Michael.
