How to fix the coordinates in a CSV file?
  • Apr 17, 2022 8:05 PM UTC
  • 7 replies
  • 85 views
Van_coordinatesScreenshot 2022-04-17 125608Hi, does anyone know how to fix the "Geom" field and turn it into appropriate coordinates? I downloaded the CSV file from the city of Vancouver open portal and ran it in the FEM workspace without changing any parameters, but I couldn't see any point features after. I was wondering if I should fix the attributes as the coordinates are within the same field? Thank you!
danilo_fme
Forum|alt.badge.img+58
  • Apr 17, 2022 11:42 PM UTC
Hi @debbiewly​
I used the transformer JSONFlattener to extract the informations that you want:
Workspace_JSON
Attached the Workspace.
Thanks in Advance,
Danilo
@debbiewly​ It is odd that the City of Vancouver distributes it's point geometry as GeoJSON. You can use the GeometryReplacer and select Geometry Encoding: GeoJSON
  • Apr 18, 2022 5:54 PM UTC
Hi @debbiewly​
Workspace_JSON
Thanks in Advance,
Danilo
It works! Thanks @danilo_fme​
danilo_fme
  • Apr 18, 2022 5:56 PM UTC
Oh Thanks your feedback! :)
  • Apr 18, 2022 6:10 PM UTC
Hi @Mark Stoakes​ , I am wondering if it is normal that the coordinates are gone after running the GeometryReplacer? Since I can no longer see the coordinates in the attribute.
DanAtSafe
Forum|alt.badge.img+23
  • Apr 18, 2022 7:11 PM UTC
@debbiewly​ By default the "Remove Attribute" parameter on the GeometryReplacer is set to "Yes". Did you change it to "No"?
use JSONFlattener to extract data.
papajohns promo codes
