How to: Feature based Filter?
pkno
Forum|alt.badge.img+5
Hello everyone,
I was wondering if there is a simple way to filter one Dataset by comparing key-values with another Dataset. Basically a Join but onlky keeping Left Attributes.
Example:
Dataset1
Project SubID moreAttributes from Dataset1
ABC 1 ...
ABC 2 ...
DE 1 ...
DE 2 ...
Dataset 2:
Project SubID different Attributes from Dataset2
ABC 1 ...
ABC 1 ...
ABC 3 ...
ABC 3 ...
DE 2 ...
FG 3 ...
I want to Filter Dataset 2 to only keep the ABC|1 and DE|2 rows because they match dataset 1. I am sure I could accomplish this via join and subsequently throw out all the Attributes that were introduced from dataset 1, but I was wondering if there is an easier way.
Thanks all
Best answer by ebygomm
Why not just keep only the projectID and SubID from dataset 1 and then use that in a FeatureJoiner of FeatureMerger?
koulsoum
Forum|alt.badge.img+10
  • March 14, 2025
Hi ​@pkno , I think you can create an attribute ‘dataset’ (dataset = 1 for the first and dataset = 2 for the second one)  then use the Transformer Matcher with Selected attribute : Project, SubID, and from the port matched use a tester to filter ‘dataset’ = 2
Forum|alt.badge.img+39
  • March 14, 2025
pkno
  • March 14, 2025
Why didn’t I think of that, that should be it. Thanks
  • March 14, 2025
You could always use an InlineQuerier, if you wanted to do it in one step
