how to extract the last two characters in a string?
  • Dec 9, 2025 7:57 PM UTC
  • 7 replies
  • 250 views
vxn43
Forum|alt.badge.img+20
I have a field with city names and state names in this format:
Oklahoma City OK
Oakland CA
Dallas TX
Forth Worth TX
Augusta ME
I want to do the following:
Extract the City name into one field and the state abbreviation into another field.
The only consistent pattern in the data is the state abbreviation always comes after the last space in the string.
I think I need to create a RegEx expression to do be able to do this.
Can someone help me with how do this?
Best answer by DanAtSafe
Hi ​@vxn43 Two SubstringExtractors might be easiest if the format is always <city name><space><state abbreviation>
DanAtSafe
Forum|alt.badge.img+23
  • Dec 9, 2025 8:25 PM UTC
sammy
Forum|alt.badge.img+27
  • Dec 9, 2025 8:31 PM UTC
Edit: I got my statements wrong and can’t seem to update this post...
 You can also do what ​@DanAtSafe suggested within the Attribute Manager if creating two new attributes:
City Name: @Substring(@Value(Original Data),0,-2)
State: @Substring(@Value(Original Data),-2,2)
sammy
  • Dec 9, 2025 8:59 PM UTC
I don’t know if this is the most efficient way to do this but it works if the data will always be structured as you say <city Name> <space> <two letter state abbreviation>.
In an attribute manager you can create two new attributes and input the following in the text editor for the values:
For City Name:  “@Left(@Value(<your original column>),(@StringLength(@Value(<your original column>))-3))”
For State:  “@Substring(@Value(<your original column>),-2,2)”
Someone else may have a cleaner way of getting the City Name. I tried using @Substring(@Value(<your original column>),0,-3) but it did not work.
danilo_fme
Forum|alt.badge.img+58
  • Dec 10, 2025 9:26 AM UTC
Good Job ​@DanAtSafe
salvaleonrp
  • Dec 10, 2025 12:08 PM UTC
​@danilo_fme I love the font… Ink free?
DanAtSafe
  • Dec 10, 2025 4:31 PM UTC
​@salvaleonrp 😉Yes, it’s Ink Free.
danilo_fme
  • Dec 10, 2025 4:41 PM UTC
Yep ​@salvaleonrp
