How to extract properties from IFC model group
  • Jul 17, 2021 7:45 AM UTC
  • 129 views
yipchoyui1
Participant
I'm trying to convert an IFC file to Esri Geodatabase format. Is it possible to convert the properties from IFC group ? If so, how could I do that.
The properties set is not visible in the traits or the elements object underneath the group layer. I am not sure if that is possible. But the result is visible from the FSKviewer.
Please offer me help!
daveatsafe
Forum|alt.badge.img+24
  • Jul 19, 2021 10:29 PM UTC
Hi @yipchoyui1​,
Would you be able to share a copy of your IFC file? It would help me in finding the properties you are looking for, or to pass on to our development team if an enhancement to our IFC reader is required. If you do not want to make the file public, you can contact me directly at dave.campanas@safe.com.
oppetveiten
Forum|alt.badge.img+7
  • Jul 29, 2024 12:02 PM UTC
hi,
did you reach any solution on this problem? I’m reading an IFC-file in FME Form 2023 and cannot expose the group name, visible in Solibri ( image below).
