How to extract geodatabase coded domain (long intger) attributes ( text values ) with the field names?
  • Jan 14, 2019 7:33 AM UTC
  • 6 replies
  • 141 views
I'm using FME 2018 with default python settings, I got the attached work space and it doesn't work because of the python problem , I don't know much about python or the coding of the transformers . @daleatsafe @boubcher @takashi
Best answer by daveatsafe
Hi @omarabdelghany,
The Python dialog is just a warning - the workspace should run fine if you hit the OK button. Luckily, my colleague @DebbiAtSafe has also updated this workspace to Python 3.4, so you may want to try that version, which can be downloaded from:
https://knowledge.safe.com/storage/attachments/23151-extract-domains-from-geodatabase-gdb-py34.fmw
  • Jan 14, 2019 10:38 AM UTC
FYI, the attachments are broken... Can you please try to repost them?
@david_r @DaveAtSafe
here is the message for python and the workspace
  • Jan 14, 2019 1:00 PM UTC
Why are you using a text file reader to extract geodatabase domains, what is the input file?
What is the source of this workspace?
daveatsafe
Forum|alt.badge.img+24
  • Jan 14, 2019 5:14 PM UTC
Hi @omarabdelghany,
the source of the work space is Esri geodatabase , these reader and writer shown in the pics is a template work space from FME knowledge center.
