How to export the metadata stored in a fileGDB to an XML file?
  • Sep 10, 2024 3:12 AM UTC
  • 58 views
nicholas
Forum|alt.badge.img+14
I have a fileGDB with a single feature class, and that feature class has metadata.
How do I export that metadata to an XML file?
I am using FME Desktop (FME Form) 2022.1
Forum|alt.badge.img+54
  • Sep 10, 2024 9:24 AM UTC
Within the File Geodb Reader there’s an option to set Feature Read Mode to Metadata. This will return the xml metadata in an attribute called geodb_metadata_string which you can then write out to an xml file
