how to downloads data from an FTP server using FME
  • June 17, 2024
  • 417 views
marjan_nikoukar
I have FTP Link, User, and Password
How Can I download a file using FTPCaller?
Thank you for your assistance
nielsgerrits
Forum|alt.badge.img+64
  • Creator to initiate process.
  • FTPCaller to list items.
    • Set username & password in Authentication. FTP link in URL.
  • Parse link to file you need. Something like ftp://download.me.com/file.txt
  • FTPCaller to download item.
marjan_nikoukar
Thank you so much for your response. would you mind explain more about how to do list item part? and what should I do for last two steps?
I really appreciate your assistance
chandcole
Participant
  • Participant
  • January 10, 2025
How do I download all the zip files in the directory from an FTP site?
virtualcitymatt
Forum|alt.badge.img+47
This is a bit annoying to do, the response from a request to a directory with the FTPCaller is a file list.
The file list needs to be split up into features to make subsequent requests for every file. There is a CustomTransformer on the FME hub called S(FTP)-2-Features which looks like has been put together to split up the request into a list of features. I haven’t tested it but I would definitly try that.
Once you have your list of features then you can pass them into another FTPCaller to download the files.
