How to determine my FME Server email address
  • Jan 19, 2016 2:30 PM UTC
  • 5 replies
  • 110 views
I'm still pretty new at FME Server. How do you determine the FME Server email address to send email data to with attachments? I'm at a loss to figure that out.
  • Jan 19, 2016 2:37 PM UTC
Hi
Have a look at this article.
David
jpvo
  • Jan 19, 2016 2:38 PM UTC
On FME Server 2015 you go on Manage>Notifications>Subscriptions and you can Edit / Create Email subscriptions and specify EmailTO, EmailFROM, EmailCC...
Alternatively you can use the custom transformer FMEServerEmailGenerator that will help you define all these parameters.
David you're too fast... ;-)
  • Jan 19, 2016 2:47 PM UTC
JP, at least your answer was a bit more thorough ;-)
  • Jan 19, 2016 2:48 PM UTC
Hi
David
David,
I was reading this article yesterday and the part of it I got stuck on is when it says send an email to demoEmailUser@yourFMEServer to test it. It's the "yourFMEServer" part of the tutorial I do not know what to fill in. I'm calling the Email Username "demoEmailUser" just like they have it in the tutorial.
Thanks
Tony
  • Jan 19, 2016 2:58 PM UTC
David,
Thanks
Tony
Hi Tony
If you're using the "Option A" (using the SMTP Relay service), then "yourFMEServer" should be the host name of your server where the "FME Server SMTP Relay" service runs.
So if you access the FME Server GUI using with your browser on e.g. http://server01.domain.com/fmeserver then you should probably send your email to either "user@server01" or "user@server01.domain.com".
David
