How to delete json key by JSONUpdater
  • Jun 16, 2016 9:41 AM UTC
  • 141 views
endest
How to delete the key "x" in a json attribute by JsonUpdater transformer:
{ "x" : "aa", "y" : "bb" }
I send the feature both into the ports of "Document" and "Update", and set
Update Type: "Delete From Object"
JSON Path: json[*]
Object / Array Index: x
but get warnings below:
2016-06-16 17:27:38| 0.2| 0.2|WARN |JSONUpdater(XQueryFactory2): The following error occurred while executing query number 1:
2016-06-16 17:27:38| 0.2| 0.0|WARN |JSONUpdater(XQueryFactory2): The following error occurred near line 3, column 21 of the query:
2016-06-16 17:27:38| 0.2| 0.0|WARN |JSONUpdater(XQueryFactory2): xs:string can not be promoted to parameter type json-item() of function json-item-accessor()
Thanks
  • Jun 16, 2016 10:20 AM UTC
Hi @endest, json[*] indicates any member belonging to the root value, so your setting means "remove x from any member object contained by the root". You can set just json to the JSON Path to indicate the root. Try this.
  • JSON Path: json
helmoet
Forum|alt.badge.img+8
  • Dec 6, 2016 7:35 AM UTC
Works fine!
martinkoch
Forum|alt.badge.img+26
  • Aug 7, 2019 7:28 AM UTC
  • JSON Path: json
And again... Takashi saves my day ;-)
I started off with json[*] and no result, but now it makes sense...
