How to convert ZFS directory to LAS?
  • Jun 11, 2018 2:32 PM UTC
  • 107 views
I'm trying to convert ZFS directory to LAS but it's not working. There's an error warning: 'Data type of the file not supported, please update library'. What went wrong?
trentatsafe
Forum|alt.badge.img+7
Hi @jkubacka,
Are you able to share your workspace and a sample of your dataset here? Alternatively, if you would prefer not to share your work in a public forum you can submit a support case here: https://www.safe.com/support/report-a-problem/
  • Jun 12, 2018 9:18 AM UTC
Thanks for responding. I guess I've found out what happened. My pointcloud data is from the newest scanner, Z+F Imager 5016. Those scans didn't work when trying to convert via FME into LAS. But I also used ZFS data from older scanners, for example the Z+F Imager 5010 and it worked!
So it's both .zfs data but the newest version doesn't work. Is there any explanation ? It took me a long time to figure that out. Maybe you have an idea? Thanks alot.
lars_de_vries
Forum|alt.badge.img+10
Maybe there is an updated version of the file format? Not sure, but probably someone who can tell you that.
