How to convert xml to Excel table
  • Jul 24, 2018 2:27 PM UTC
  • 11 replies
  • 470 views
new here. Just want to ask how do I extract data from xml below into an Excel Table. Problem I specifically can't get over with is how to make the attribute name into a column heading in Excel and how to extract from inside the groups.
Cheers.
<?xml version="1.0" encoding="windows-1252" ?>
<file name="EMP_RECORD" version="3.0.0">
<schema>
<group name="EMP_RECORD_HOURS_DAY_DATE">
<field name="HOURS_DAY_DATE">
<desc>Effective Date</desc>
<just>R</just>
<len>12</len>
<type>DATE</type>
</field>
<field name="HOURS_DAY_CODE">
<desc>Hours/Days Register</desc>
<just>L</just>
<len>2</len>
<type>VARCHAR</type>
</field>
<field name="PAY_GROUP">
<desc>PAY_GROUP</desc>
<just>L</just>
<len>20</len>
<foreign_key>
<target_file>PAY_GROUPS</target_file>
<key_parts>PAY_GROUP</key_parts>
</foreign_key>
</field>
<field name="WORK_PATTERN_CODE">
<desc>WORK_PATTERN_CODE</desc>
<just>L</just>
<len>20</len>
</field>
<field name="WORK_PATTERN_WEEK">
<desc>WORK_PATTERN_WEEK</desc>
<just>R</just>
<len>14</len>
<type>INTEGER</type>
</field>
</group>
<field name="SURNAME">
<desc>Surname</desc>
<just>L</just>
<len>20</len>
</field>
<field name="TITLE">
<desc>Title</desc>
<just>L</just>
<len>4</len>
<type></type>
</field>
<field name="FIRST_NAME">
<desc>First Name</desc>
<just>L</just>
<len>20</len>
<type></type>
</field>
<field name="PREF_NAME">
<desc>Preferred Name</desc>
<just>L</just>
<len>15</len>
</field>
</schema>
<data>
<row key="Emp1">
<field name="HOURS_DAY_DATE">09 JAN 2001</field>
<field name="HOURS_DAY_CODE">14</field>
</group>
<field name="SURNAME">DOE</field>
<field name="TITLE">MS</field>
<field name="FIRST_NAME">JANE</field>
<field name="PREF_NAME">JANE</field>
</row>
<row key="Emp2">
<field name="HOURS_DAY_DATE">19 JAN 2001</field>
</group>
<field name="SURNAME">SMITH</field>
<field name="TITLE">MR</field>
<field name="FIRST_NAME">JOHN</field>
<field name="PREF_NAME">JOHN</field>
</row>
</data>
</file>
Best answer by takashi
If I understood the requirement correctly, the XMLFragmenter and the XMLXQueryExtractor might help you.
XQeury Expression Example:
for $f in //field
return fme:set-attribute($f/@name, data($f))
  • Jul 24, 2018 3:54 PM UTC
Hi @kburata,
You may try using the XML reader and Feature Paths to select the attributes that you're interested in.
Result would look something like this:
  • Jul 25, 2018 1:20 AM UTC
Hi @kburata,
Hi @guthima, ideally I would be able to get data out of "data" part and concert it into a table.
  • Jul 25, 2018 2:11 AM UTC
for $f in //field
  • Jul 25, 2018 2:48 AM UTC
for $f in //field
Hi @takashi, how do I expose row.key though?
  • Jul 25, 2018 3:00 AM UTC
for $f in //field
Modify the XQuery expression as:
fme:set-attribute('ROW_KEY', data(/row/@key)),
for $f in //field
and expose "ROW_KEY" additionally via the Attributes to Expose parameter.
  • Jul 25, 2018 3:22 AM UTC
for $f in //field
Awesome mate. cheers!
  • Jul 25, 2018 7:41 AM UTC
for $f in //field
Hi @takashi,
If my xml was changed to the one below, how would I change the xquery to set the attribute of the 2nd given names to MIDDLE_NAME or split them into GIVEN_NAME1 and GIVEN_NAME2.
I have this right now but having an error setting the variable's value to check if still within the same ROWKEY as I cycle through the fields. Is this possible?
Cheers
  • Jul 25, 2018 8:04 AM UTC
Hi @takashi,
Cheers
In your example, both "JANE" and "BEVERLY" belong to the same field "GIVEN_NAMES", whereas FME feature can only have a single value for each attribute. The solution would be different depending on your desired result. Which one?
  1. Create two attributes. e.g. GIVEN_NAMES1 = JANE, GIVEN_NAMES2 = BEVERLY.
  2. Create a list attribute containing the two values. e.g. GIVEN_NAME{0} = JANE, GIVEN_NAMES{1} = BEVERLY.
  3. Other?
  • Jul 25, 2018 8:23 AM UTC
  3. Other?
The 1st one?
  • Jul 25, 2018 8:42 AM UTC
for $f in //field
This is a possible expression.
for $f at $i in /row/group[@name = 'HR_SHARED_GIVEN_NAMES']/field
return fme:set-attribute($f/@name||$i, data($f)),
for $f in /row/group[@name != 'HR_SHARED_GIVEN_NAMES']/field
return fme:set-attribute($f/@name, data($f)),
for $f in /row/field
  • Jul 25, 2018 8:48 AM UTC
This is awesome! Thanks a lot.
Will have to brush up on my xquery skills.
