How to convert a file CSV to oracle table (type POINT object)
  • Feb 12, 2016 7:34 PM UTC
  • 9 replies
  • 122 views
I have created a graphic ORACLE table from a CSV file. The CSV file contains the coordinates X and Y to create points. Now the ORACLE table contains the points but the graphic column contains null values.
It seems that I must :
1. Check the types of geometry it is passing to writer (i.e. line / point) , but how to do what ?
2. Define the parameter " oracle_type " with an attribute creator, but which value "point" or "oracle_point" or "SDO_point" ?
Thanks you for yours answers
erik_jan
Forum|alt.badge.img+26
  • Feb 12, 2016 7:38 PM UTC
Dis you use the "Oracle Spatial Objects" writer. It seems you are using the "Oracle Non-Spatial" writer and hat one does not write the Spatial (geometry) column to Oracle.
Yes I have used the "Oracle Spatial Objects" writer and I have indicated the name of the Spatial (geometry) column (=> GEOM)
erik_jan
  • Feb 12, 2016 7:52 PM UTC
How did you read the X and Y columns in the CSV reader. If you add the CSV reader you can change the type for X and Y to coordinates as shown in the image:
That will create the point geometry.
I have used the "2dpointreplacer" and "CoordinateSystemSetter" transformers to do that. I have not used the type for X_coordonate and Y_coordonate to coordinate.
erik_jan
  • Feb 12, 2016 8:08 PM UTC
If you redirect your output (writers menu) to the inspector, what is the value of the fme_type (should be fme_point) attribute, and do you see any attributes starting with oracle_ ?
for the first question the value of the fme_type (fme_point) attribute i can't answer you, it is the wee-end. for the second question yes I see the diferents lines and the others attributes but the Spatial (geometry) column is null
erik_jan
  • Feb 12, 2016 8:26 PM UTC
DO you read any data from an Oracle table in this workspace (for example an ID from a sequence in a SQLExecutor or additional attributes from a non spatial Oracle table)? Because that would lead to an attribute oracle_geometry with value oracle_nil and that would explain why the geometry is not written. If so, use the BulkAttributeRemover with these settings:
Yes I can read any data from an Oracle table in this workspace. (oracle spatial table or not oracle spatial table). So I will test the BulkAttributeRemover transformer to resolve my problem. Thanks you for your help
I found the solution this morning. In the output parameters there is a parameter named "Allowed Geometries" but it is fixed to "All" and I can't change it.
The solution is to create an attribute named "oracle_type" and to define this parameter with "oracle_point" value. And to expose the ORACLE output parameter named "oracle_type".
