When trying to use the SQL Azure SQL Database (JDBC) database connection, can that be used with the ActiveDirectoryPassword authentication type? I have a service account in the Azure Active Directory, but that is not the user our FME Server runs with, to be able to use the ActiveDirectoryIntegrated option. I have successfully used FME Desktop with my personal account as well as the service account (using RunAs) with the ActiveDirectoryIntegrated authentication. Any help you can provide would be very much appreciated.
