How to configure MongoDB Atlas in FME Workbench database connection
  • Jul 6, 2021 7:37 AM UTC
  • 132 views
rob_braggaar
Forum|alt.badge.img+5
I have the following MongoDB Atlas cluster, hosted at Google Cloud, to which I'd like to connect in FME Workbench.
clusterFME should be capable of connecting but I did not find the right settings yet to do so.
In my Node.js Express app I'm using a connection string which includes the username and password as well as the database. In FME these are separate fields.
The connection string looks like so:
stringIn FME I think this translates to this, but it does not work for me. And what do I fill in for authentication database name?database connection
I'm stuck at the following error message:
error
Any thoughts much appreciated!
kailinatsafe
Forum|alt.badge.img+24
Hello @rob_braggaar​, what version of FME Worbench are you using? Would you mind trying this in the latest release of 2021, or even the last release of 2020.2? Best, Kailin.
rob_braggaar
  • Jul 10, 2021 3:38 PM UTC
I'm using FME Workbench 2021.1. Expand the post to see the log results attached.
fme mongoThis is what happens when I test the connection:
MONGODB reader: Cannot connect: no unix socket support on windows
MONGODB reader: Failed to open the dataset 'MongoDB:'. Please ensure source data is valid and correct reader is selected
MONGODB reader: A fatal error has occurred. Check the logfile above for details
Failed to read schema features from dataset 'cluster0.xpnrd.gcp.mongodb.net/lets-production' using the 'MONGODB' reader
rob_braggaar
  • Jul 27, 2021 2:18 PM UTC
@kailinatsafe​ could you confirm those settings should be compatible with FME Workbench? Thanks in advance.
