How to combine two CityGML files into one?
  • Sep 19, 2017 2:18 PM UTC
  • 215 views
I am trying to create one CityGML file based on two others. Both have the same CRS.
I am not sure if I have to use transformers and if yes which ones?
It did not work with only two readers and one writer.
Maybe there is a solution by using XML-Transformers and the "CityObjectMember".
It sounds like an easy task but I am new to FME.
By the way, I am using FME Desktop 2017.1
Thanks,
The Cartographer ;-)
daveatsafe
Forum|alt.badge.img+24
  • Sep 19, 2017 6:06 PM UTC
Hi @thecartographer,
A workspace that reads form both CityGML files and writes to a new one should work fine. What problems are you seeing with your output CityGML file? Would you be able to share your workspace and source CityGML files with me?
Thank you for your quick reply!
I tried again and it works now.
My next step is to add a geotiff file (DEM) to the exisiting CityGML file.
Is there anything I have to consider?
greetings,
The Cartographer
daveatsafe
  • Sep 20, 2017 2:49 PM UTC
greetings,
The Cartographer
CityGML needs a surface rather than the raster you are going to get from the GeoTIFF files, so I would use a SurfaceModeller to create a surface from the GeoTIFF input before writing to CityGML.
daveatsafe
  • Sep 21, 2017 5:15 PM UTC
A workspace that reads from both CityGML files and writes to a new one should work fine.
