How to check existing files in a folder from a transformer ? (not a Path reader)
Forum|alt.badge.img+4
Hello everyone,
I am currently trying to get a list of existing file names inside a folder.
Here are some explanations :
- I have a Path reader which reads existing files in a folder (let's call it folder 1). In this folder, there should be one text file;
- If the text file exists, I use a FeatureReader to read it. This text file contains several paths to other directories (folders 2, 3, …, n).
- Once I extracted those new path, I want to do the same as with the reader : get the names of the existing files inside folders 2,...,n.
For now, I know how to read files from within the Workbench, with a FeatureReader.
But how can I do the exact same thing as the Path reader without using one ? I do not need to read the files right away, I just want to get the names of the files Inside folders 2,...,n.
The idea is to do all those operations in the same fmw script.
Any idea ?
Best answer by koen
You could use another FeatureReader with Format='Directory and File Pathnames'. It should the same as the Path reader.
Forum|alt.badge.img+50
Is there a reason why you don't want to use the Path reader?
I guess you can try and do the same using a Systemcaller, on Windows the dir command, pipe that to a text file and then read that with a FeatureReader, see if the text file you need is in there and then use a second FeatureReader to read that.
koen
Forum|alt.badge.img+10
  • July 13, 2020
  • July 13, 2020
It works great. I did not know I could use this format with FeatureReader. Thank you !
  • July 13, 2020
It should work as well but it seems a little longer and requires to generate a new text file. Since I am working on an automated process, we want to reduce the amount of temporary files between each script as much as we can, so I am going to use the other solution. Nonetheless, Thank you for your answer !
Yeah, I kinda misinterpreted what you were trying to do :)
