How to add nodes on a line with point data
  • October 10, 2024
  • 84 views
emerson_styles
Forum|alt.badge.img+4
I’m doing a routing analysis and I have a road network that I need to create new nodes along where I have points for addresses. I used the AnchoredSnapper transformer to ensure that the points align with the line data. The point data (addresses) is a separate dataset from the line data (network).
Does anyone know how to create new nodes along an existing line using point data?
emerson_styles
  • October 10, 2024
^ I’ve figured out that it’s possible to do this with the TopologyBuilder transformer.
liamfez
Forum|alt.badge.img+43
  • 278 replies
  • October 10, 2024
You can do this with a number of transformers, the PointOnLineOverlayer would also work.
