How to add active directory user to access fme server and run workspace
  • August 8, 2017
  • 96 views
we have configured our Active Directory with FME server and some active directory user already added to access and run FME workspace.
But when I try to add new user then its asking to set password. we no need to set password. User can use there AD default password.
courtney_m
Forum|alt.badge.img+12
  • August 8, 2017
If you add a new user via FME Server, you are actually adding an FME Server user, which requires a password. In order to add a new AD user, you would need to add it on the AD Server, then import it into FME Server.
-Courtney
