I've created a workspace you can point at any folder containing multiple shape files, and outputs an access mdb files that simply summarizes the counts and present attributes for each shape. The problem is however, FME seems to ignore “Empty” shape files. This is somewhat understandable, but is there any way I can bypass it? The nature of the tasks this workbench has to perform dictates that it also needs to list the empty features. The count will be zero for these specific layers, but I still need them to be added to the output file.
I’ve done several tests, and it doesn’t seem like the empty layers get thrown away at any of the specific transformers, so I’m guessing that it’s an inherent feature of FME it self? Or am I missing something?
Thanks in advance,
