How does FME detect that GPSBabel is installed?
  • October 17, 2017
  • 7 replies
  • 99 views
helmoet
Forum|alt.badge.img+8
We are trying to distribute FME Workbench through Microsoft Virtualization and for that we would like to know how FME detects that GPSBabel is installed. In our current setup GPS-like readers and writers and their feature types are correctly placed in the workspace, however, running the workspace  fails, telling:
FME API version of module 'NULL' matches current internal version (3.8 20160224)Creating reader for format: TomTom POITrying to find a DYNAMIC plugin for reader named `TOMTOM_POI'
Loaded module 'TOMTOM_POI' from file 'E:\App-V_5\D52C8804-9F50-4D7B-A695-142DCEFE7A5E\87B5596E-AF57-4FA1-B219-EA631F902A79\Root\VFS\ProgramFilesX64\FME\plugins/GDAL.dll'
FME API version of module 'TOMTOM_POI' matches current internal version (3.8 20160224)
TOMTOM_POI reader: Opening file 'Z:\Temp\Webfleet\gulocPlStr16.ov2'
TOMTOM_POI reader: Could not create process gpsbabel -i tomtom -f Z:\Temp\Webfleet\gulocPlStr16.ov2 -o gpx,gpxver=1.1 -F C:\Users\ex19111\AppData\Local\Temp\13\16688_0
TOMTOM_POI reader: Failed to open the dataset 'GPSBABEL:tomtom:Z:\Temp\Webfleet\gulocPlStr16.ov2'. Please ensure source data is valid and correct reader is selected
A fatal error has occurred. Check the logfile above for detailsFME Session Duration: 1.3 seconds. (CPU: 0.2s user, 0.4s system)
There seems to be not very much documentation on this except that FME needs GPSBabel to read/write GPS-like formats.
We are trying to install FME 2016.1.2.1 (20160929 - Build 16674 - WIN64) on
Microsoft Windows Server 2008 R2 Server 4.0, Enterprise Edition 64-bit Service Pack 1 (Build 7601).
We are using app-V 5.1, however, we're not stuck to FME 2016 and even planning to skip this and use FME 2017.1.
Looking at the logging, I would say FME does a blind call to GPSBabel executable, that fails. Anyone has experience in this kind of setups?
Best answer by helmoet
Hi, I found a solution. The problem was that FME just calls gpsbabel.exe and apparently leaves it to the operating system to find the correct location of the program. So I created a .bat file that starts FME and prior to that extends the PATH environment variable with the path to GPSBabel.exe (which in our case is a bit complex since it is in an App-V bubble, nevertheless, it works).
  • October 17, 2017
Just a hunch, could it be that GPSBABEL is only supported on 32-bit FME? I had a look at the GPSBabel project website, and it looks like it's only available on Windows as a 32-bit version.
  • October 17, 2017
I just did a bit of research, it seems 32-bit FME is looking for the following registry key on 64-bit Windows:
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\{1B8FE958-A304-4902-BF7A-4E2F0F5B7017}_is1
The key might be slightly different for 64-bit FME on 64-bit Windows.
Search the registry for "{1B8FE958-A304-4902-BF7A-4E2F0F5B7017}_is1" and see what you can find, both on the machines where it works and where it doesn't work.
  • October 17, 2017
Hm. That shouldn't be the case, according to the supported formats list, I see now.
erik_jan
Forum|alt.badge.img+26
  • October 17, 2017
As far as I know, GPSBabel is no longer required to read and write the GPX format.
It used to be for older FME versions.
  • October 17, 2017
It seems to still be required for the TOMTOM_POI format, however.
See: https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_ReadersWriters/tomtom_poi/tomtom_poi.htm
helmoet
  • October 20, 2017
Thanks @erik_jan and @david_r for the response. It is especially the TomTom POI .ov2 format that we need, so I will have a look into the registry keys.
It works on my machine (64bit Windows 8, 64bit FME, 32bit GPSBabel), and at least, there is more people saying that GPSBabel runs on 64bit Windows, see
http://www.google.nl/url?sa=t&rct;=j&q;=&esrc;=s&source;=web&cd;=1&cad;=rja&uact;=8&ved;=0ahUKEwjx54b81f7WAhVOJFAKHS9FD00QFggmMAA&url;=http%3A%2F%2Fgpsbabel.en.lo4d.com%2F&usg;=AOvVaw2JVjKC9v9QWYSFZD986tp-
helmoet
  • October 20, 2017
