How do you get the fme_basename parameter to update for each filename opened in a workspace runner?
  • Jun 8, 2018 2:42 PM UTC
  • 81 views
philipwhitten
Forum|alt.badge.img+15
I need to copy all of the features in a folder containing many zipped shapefiles to tables in a SQL Server.  The table names in the SQL Server need to reflect the shapefile names.  Currently I am using the Table Name Expression:
NatTitl_@Value(fme_basename)
When I run the workspace runner that I created, the same table name is applied to every shape file.  Hence, the fme_basename parameter is not updating when a subsequent shapefile is opened.
  • Jun 8, 2018 8:22 PM UTC
Consider using "fme_feature_type" instead of "fme_basename". "fme_feature_type" stores feature type name, which is equal to the source file name without extension if the source format is a folder-based one, such as Esri Shapefile.
philipwhitten
  • Jun 12, 2018 2:54 AM UTC
The problem occurs regardless of whether fme_basename or fme_feature_type is used. I have attached the fme files with fme_feature_type instead of fme_basename.
I don't understand how changing the parameter to fme_feature_type from fme_basename presents a solution to the question?
