How do I use JAVA_OPTS in a JDBC connection
  • Jul 29, 2019 5:26 PM UTC
  • 0 replies
  • 94 views
fmelizard
Forum|alt.badge.img+22
If your looking to make a connection with JDBC Reader and you need to specify JAVA_OPTS you can do the following:
1) ADD a new multi-parameter System Environment Variable called JAVA_TOOL_OPTIONS and specify your paramters.
JAVA_TOOL_OPTIONS = -Djava.security.login.config=C:\folder\some.config -Djava=anothervalue
2) Restart FME
