How do I get the folder name for my features stored in a KML/KMZ file?
  • Sep 30, 2016 9:18 PM UTC
  • 333 views
fmelizard
Forum|alt.badge.img+22
When I open my KML file in Google Earth, I can see the data displayed in folders in the table of contents. When I use the KML reader to read the data, that folder name doesn't show up on my features. How do I get that out?
Best answer by laurawatsafe
The folder name isn't added as an attribute onto placemarks read from KML directly. The folders themselves are read separately as a feature type called Folders. The Placemarks will have a format attribute added to them called kml_parent which contains an id value that will match the kml_id from one of the Folder features. To add the folder name onto the Placemarks, you can use a FeatureMerger transformer to join on those two attributes.
Here's a sample template file to show how that would look within FME: kmlgetfoldername.fmwt
laurawatsafe
Forum|alt.badge.img+14
  • Sep 30, 2016 9:22 PM UTC
  • Aug 11, 2021 6:02 PM UTC
Where can I find the file described above (​kmlgetfoldername.fmwt)?
laurawatsafe
Thanks @kerkhoff​! I'm attaching that file to this comment.
  • Aug 18, 2021 6:02 AM UTC
Thanks Laura at Safe.
