How do I convert las to point shapefile?
  • January 24, 2017
  • 180 views
The questions speaks for itself. If I simply connect a shp writer the output has no geometry
itay
Forum|alt.badge.img+17
  • January 24, 2017
Hi @robertdbuckley, you need to decompose the pc geometry with the PointCloudCoercer and make sure the correct geometry type is selected on the writer (point, multipoint)
Hope this helps.
