how could i remove the unwanted part after detecting the self intersection?
gogopotter90
Forum|alt.badge.img+13
hello ,
i have detected self intersection with geometry validator
does it possible to convert the line that detected to straight line ?
I do not need the triangle at image (I have detected the issue location with geometry validator ,but how could I remove the part unwanted that occurs it ) .thanks in advance
Fme 2021
Best answer by DanAtSafe
 @gogopotter90 The repaired feature that comes out of the GeometryValidator will be an aggregate of 3 lines.  You could pass that into an AreaBuilder - the Incomplete features will be the lines (not the triangle).  Join those together with a LineCombiner.
DanAtSafe
Forum|alt.badge.img+18
  • March 1, 2024
  • March 2, 2024
Hi @gogopotter90 ,
You can also use a ClosedCurveFilter instead of the AreaBuilder in the proceduer suggested by @DanAtSafe.
