How convert to .KML from .DWG ? how to know which transforms to use ?
Hi everyone, i hope you re doing well .
i need to convert some dwg files to kml , my internship boss told me to use FME .
i am new to FME , i am asking which transformers i need and how configure them ?
i will attach one of my dwg files. please see it and tell me how to proceed.
thank you so much.
  • June 9, 2021
Try using the "Generate workspace" function in FME:
https://safe-software.gitbooks.io/introduction-to-fme-desktop/content/2.translations/2.02.generate-workspace.html
It will give you a starting point and you can take it from there.
  • June 9, 2021
Thank you @david_r (Partner)​ for your reply .
In fact, i was told to create some FME Workflow to get the KML output, with attributes and so on .
and i am asking how can i do that ? and how to know which transformers to use ?
i really appreciate your help .
  • June 9, 2021
Did you already try the Generate Workspace function?
  • June 9, 2021
yes, i tried it , thank you for the information .
but my internship 's purpose is to create the dwg2kml FME Workflow , this is logical ,isn't it ?
