How can I specify a projection for a mongodb destination ?
  • Aug 14, 2023 3:20 PM UTC
  • 95 views
pierre.bodin
Forum|alt.badge.img+12
Mongodb supports EPSG 4326 by default you can specify a custom crs : https://www.mongodb.com/docs/manual/reference/operator/query/geometry/
My workflow is simple : geopackage to mongodb.
I tried :
  • Specify source and destination projection : no effect (data are in 4326 in mongo)
  • Extract geometry (projected in 2154) and store in attribute geometry2 but there is no json type (or even geometry type).
  • Extract geometry and write it in a geometry attribute : fme returns an error.
evieatsafe
Forum|alt.badge.img+28
  • Aug 16, 2023 5:16 PM UTC
Hi @Pierre Bodin​ thanks for your question! I'm personally not sure the best solution for this, although I am curious -- what was the error returned by FME when you extracted the geometry and tried to write it to a geometry attribute?
I also want to make sure that you are trying to write to a new MongoDB and set the projection, not an existing DB?
pierre.bodin
  • Aug 21, 2023 12:36 PM UTC
Sorry for late response !
Here is the error :
MONGODB3 writer: CreateFeature(): Can't extract geo keys: ... : generic server error
I create a new collection (not a new DB but seems fine ? )
