How can i read csv file daily?
  • Sep 14, 2018 2:40 PM UTC
  • 64 views
Hello, I am a new FME user. im gonna store csv file in one folder daily. (ex. 20180914.csv)
If it comes in daily, is there a way to read only today's csv file?
Thanks in advanced.
  • Sep 14, 2018 2:57 PM UTC
Try using a DateTimeStamper to create the filename using today's date, then send it to a FeatureReader configured for your CSV.
  • Feb 25, 2020 5:29 PM UTC
How would you reformat this if the date needs to be in MMDDYYYY format?
chrisatsafe
Hi @datacrypt,
If you would like to reformat the date to MMDDYYYY, you could place a DateTimeConverter after the DateTimeStamper. Then, in the DateTimeConverter parameters, set the Output Format to:
%m%d%Y
Or in the format you prefer. We have an awesome doc that covers the Format String Flags and Examples that can help you figure out which flag to use in order to get your expected output.
Another helpful thing inside the DateTimeConverter is the Preview Data section as it will show you an example of what the output will look like:
Hope that helps.
