How can I merge identical sheets in excel to 1 table with diffent colomns?
  • Apr 28, 2020 2:05 PM UTC
  • 68 views
karelatvmm
Participant
Hello,
I have a excel with al lot of sheets per region (500 different names). All have the same form.
On each sheet in different rows, I have measurements for each day. (Timestamp : 365 d)
The name is in the sheet (yellow) and also in the sheetname (tab).
Now I want a table where for each day, I have a new colomn per region.
Example for 3 regions is attached, also how the result should look like.
Thanks for any tip!
Forum|alt.badge.img+54
  • Apr 29, 2020 7:20 AM UTC
Does it need to be dynamic, or can you manually import the list of names to expose?
If you need to do it dynamically it's a bit more complex
merge_sheets.fmwt
merge_sheets_dynamic.fmwt
karelatvmm
Participant
  • Participant
  • Apr 29, 2020 7:22 AM UTC
merge_sheets.fmwt
I should be able to make a list of all the sheetnames. So not dynamic I think.
  • Apr 29, 2020 7:31 AM UTC
I've amended the answer to include an example
karelatvmm
Participant
  • Participant
  • Apr 29, 2020 10:37 AM UTC
merge_sheets.fmwt
Thanks is exactly what I needed !! SUPER! Having fun with FME !
