How can I generate CityGML file with number of storey attribute values from shp file?
  • Nov 2, 2016 2:44 PM UTC
  • 80 views
I am trying to convert shp file to cityGML. In shapefile I have building footprints with attributes "storey" as number of storeys. I want to match this attribute to number of storeys attributes of cityGML buildings class. How can I make this?
itay
Forum|alt.badge.img+19
  • Nov 2, 2016 5:06 PM UTC
Hi @ziyausta61, writing GML can be easy and complex depending on the what you want to achieve.
These are some links that might set you on the right direction.
https://knowledge.safe.com/articles/775/inspire-gml-basic-writing-example.html
https://knowledge.safe.com/articles/812/gml-writing-with-application-schemas.html
Hope this helps.
  • Jul 25, 2017 3:05 PM UTC
I have the same problem, has anyone solved the problem?
fmelizard
Forum|alt.badge.img+22
  • Jul 25, 2017 3:13 PM UTC
Hi @ajgzzc. I would suggest posting your question as a new question as you will likely get more responses this way. Including the following details in the new question will help the FME community help you. Please provide details including:
  • The version of FME you are using, including build number and edition
  • A small sample of your data, or screenshots of the data in the FME Data Inspector
  • A description of your expected output, with screenshots if possible
  • Your FME workspace
  • Your FME translation log file
  • Any other information that may be useful to share
I would also suggest checking out the BIM Tutorial
