How can i create an non-spatial index in de Oracle-Spatial writer?
  • Mar 14, 2016 2:39 PM UTC
  • 74 views
jpdenboer
I want is create (even) an non-spatial index in the Oracle-spatial writer. So i tried the "SQL Statement to execute After Translation" with the next SQL:
CREATE INDEX GBKN_ALLES_TST_INDEX ON GBKN_ALLES_TST
(DWGLAYER, KLS_KLASSE)
LOGGING
STORAGE (
BUFFER_POOL DEFAULT
FLASH_CACHE DEFAULT
CELL_FLASH_CACHE DEFAULT
NOPARALLEL;
But it failed...
error was `ORA-00911: invalid character'
What is wrong?
Best answer by david_r
Hi
Try removing the semi-colon at the end.
David
  • Mar 14, 2016 2:44 PM UTC
Hi
David
Forum|alt.badge.img+5
  • Mar 14, 2016 2:48 PM UTC
Hi
David
You are way too fast:) Checked it on my database here, the semi-colon is indeed the problem.
  • Mar 14, 2016 3:05 PM UTC
It's always faster to reply when you've made the same mistake before ;-)
jpdenboer
  • Sep 23, 2016 2:19 PM UTC
Thank you very much! After removing the semi-colon it works well!
