How can I create a nested JSON from an Excel- or CSV-file?
stefanh
Forum|alt.badge.img+8
I have a Excel-file with the following content:
group1group2group3nameinfoGeneralNation
Philinfo1GeneralNation
Kareninfo2GeneralMunicipality
Billinfo3GeneralMunicipality
Paulinfo4SpecificProvince
Patrickinfo5SpecificProvince
Maikelinfo6SpecificProvinceGovernanceMikeinfo7SpecificProvinceGovernanceLukeinfo8SpecificDistrict
Mariainfo9SpecificDistrict
Davidinfo10
The attributes can be adjusted it is a Excel-file; I create the file myself.
I would like to automatically create a nested JSON file.
This should look like this:
  "name""Overview",
    "children": [{
        "name""General",
            "children": [
                { "name""Nation",
                    "children": [
                        {"name""Phil""info""info1"},
                        {"name""Karen""info""info2"}
                { "name""Municipality",
                    "children": [
                        {"name""Bill""info""info3"},
                        {"name""Paul""info""info4"}
        "name""Specific",
            "children": [
                { "name""Province",
                    "children": [
                        {"name""Patrick""info""info5"},
                        {"name""Maikel""info""info6"},
                        {"name""Governance",
                            "children": [
                                {"name""Mike""info""info7"},
                                {"name""Luke""info""info8"}
                { "name""District",
                    "children": [
                        {"name""Maria""info""info9"},
                        {"name""David""info""info10"}
I tried the JSONTemplater transformer, but I can't figure out how this works.
I am not sure where to put the template, either in the root or in the sub.
Hope someone can help me with this!
Kind regards,
Stefan
deanatsafe
  • March 24, 2020
The following JSON Tutorial has a JSONTemplater example very similar to the one you are describing here. If you are new to JSON writing, I would strongly recommend working through this example to get a better feel for how the templating process works for JSON generation:
https://knowledge.safe.com/articles/44294/json-writing-with-jsontemplater.html
To start with, your root template will look very similar. The root template is the part that doesnt repeat. It has only one input feature, often from a Creator set to generate a single feature. For JSON writing, often the root template is very simple and is just there to wrap the whole document and call the subtemplates. In your case it might look something like:
fme:process-features("Children")
Assuming 'Children' is the name of your top level subtemplate. Since everything else repeats, the rest of your JSON structure will go into a series of sub-templates. Note that JSON is often more deeply nested than relational tables which are limited to one level of nesting: tables composed of fields, so this is why sometimes even sub templates have sub templates. So you don't always have a 1 to 1 correspondence between input feature types and subtemplates.
The tutorial example has 2 subtemplates which are essentially children and grandchildren to the parent root template. As you can see from the tutorial, each level of nesting uses a copy of the data stream with an appropriate group-by. In your case you would likely want to have separate Samplers with the group-by set to group1, group2, and group3 respectively.
Give this a try, first with the tutorial and then with your data, and if you get stuck let us know and we can help you further.
stefanh
  • March 25, 2020
Thanks for your elaborated answer. This is very useful. It does work to some extend. The problem I face now, however is that there are records which do not have a value in attribute group3. If I add this group in a subtemplate, I get an error.
I have added the workspace.
nestedJSON example.fmwt
Forum|alt.badge.img+39
  • March 25, 2020
You can write if then else statements
There's an example here
https://knowledge.safe.com/questions/91602/json-templater-how-to-export-attributes-with-value.html
stefanh
  • March 26, 2020
This very useful! Thanks. I did make it work with my example. I used the following code in the SUB3 expression.
    if (fme:has-attribute("group3"))
    then
            fme:get-attribute("group3") : [
            fme:process-features("SUB4""group3", fme:get-attribute("group3"))
    else
    "Name" : fme:get-attribute("name"),
    "Info" : fme:get-attribute("info")
There is one more thing I can't figure out. The result I have so far is ( a part of it)
   "General" : [
         "Nation" : [
               "Name" : "Phil", "Info" : "info1"
               "Name" : "Karen", "Info" : "info2"
         "Municipality" : [
               "Name" : "Bill", "Info" : "info3"
               "Name" : "Paul", "Info" : "info4"
However it should include the text "children", but I don't know where to put this text in the expression. I have tried multiple things.
    "children": [{
        "name""General",
            "children": [
                { "name""Nation",
                    "children": [
                    "children": [
nestedJSON example 2.fmwt
stefanh
  • April 6, 2020
    then
    else
   "General" : [
         "Nation" : [
         "Municipality" : [
    "children": [{
        "name""General",
            "children": [
                { "name""Nation",
                    "children": [
                    "children": [
@deanatsafe
Hi Dean, I still haven't figured out how I could add an attribute name (not sure how to call it) to the nested JSON. So it includes the texts "name" and "children" before the actual text from the csv is added.
Hope you can help.
Thanks Stefan
