Hi, I would like to convert a Map info table file into a TIFF file but it doesn't work ! Can't you help me please
  • January 26, 2018
  • 51 views
ciarab
Forum|alt.badge.img+9
  • January 26, 2018
@mathieusthip
Is this a vector to raster conversion? You might want to try using a transformer like mapnikrasterizer
https://knowledge.safe.com/articles/1092/introduction-to-mapnikrasterizer.html
Do you have any more information on what your source data is? What is happening in your process is the output blank?
I have different kind of my source data, I have Mapinfo table file, Mapinfo table, SHP file, SHX file
I'm not sure which files is the best to convert ?
Here's the error message
FME Session Duration: 1.2 seconds. (CPU: 0.6s user, 0.2s system)
END - ProcessID: 4592, peak process memory usage: 102304 kB, current process memory usage: 102304 kB
Program Terminating
Translation FAILED.
ciarab
  • January 26, 2018
Program Terminating
Translation FAILED.
Can you add the log file or send the error information. The bit where it says a fatal error has occurred check the logfile above for details. What does the error message say was the issue?
What are you trying to display in the tiff?
