Hi, I am trying to output the results of an FME workbench to multiple files based on the value of a particular field but also add a specified value in the first row. I
I have worked out that I can use the Fanout feature on both csv and xlsx files, and I need the output as csv files, however outputting to a csv creates separate folders for each file and I need it output to the same file.
The second part is that I want the output to start writing on row 2, with each file output to have the same value in cell A1.
I know that if i output to excel i get individual files, named based on the attribute I specify, but all the files are in the same folder, which is halfway to what I want.
What I cant work out is how to:
  1. insert a specified value in cell A1 on every file; and
  2. output as a csv
Is this possible in FME or am i going to have to write a macro for excel that runs through each file, adds the value in cell A1 and then saves the file as a csv?
Best answer by tomf
Firstly to get individual csv files in the same folder you need to apply a feature type fanout. From your description it sound like you have a dataset fanout. Open the CSV writer feature type parameters and in the CSV File Name parameter select the attribute(s) you want to fanout by:
FTfanoutDon't forget to turn off the Dataset fanout (Navigator window > CSV Writer > Fanout Dataset: No)
(for excel a feature type fanout would give you multiple worksheets in the same file. Boils down to the difference between file-based and folder-based datasets)
To get a different value in the first column and row of all your csv files is a little trickier. As writing a CSV will create one line per feature, we are going to have to create a new feature for each unique value of your fanout attribute(s). Each of these will have the fanout attribute plus the specified value in the first column's attribute name. Ensuring these feature enter the csv writer feature type first (e.g., a FeatureHolder can delay the other features) they will form the first row then the rest of the features will form the remaining rows.
Others may have a better solution to the first row problem, but that would be my first approach.
tomf
Forum|alt.badge.img+14
  • March 10, 2021
  • March 17, 2021
Thanks tomf - one minor thing i missed that made all the difference with the fanout :-)
Still struggling with having a specified value in cell A1 - basically i want the first row to have the same value in cell A1 for every fanout attribute and then the attributes written to the same file starting on row 2
eg
100980.csv
Value in R1C1,,,,,,,,,,,,
ass_num,rte_cde,rte_dif,bal_cde,rte_yer,rte_unt,amount,tax,amount_inc,lev_num,dte_lev,trn_cde,Max_tran
100980,1,5,21,2004,366,914.39,0,914.39,1,00:00.0,1701,8901293
123467.csv
123467,1,5,21,2018,365,1477.48,0,1477.48,1,00:00.0,1701,8901293
so in actual fact the values in the first two rows are identical - the values in row 2 are output by the fanout as is the data in row 3 - just need to have the value in row 1 added to each file
tomf
  • March 17, 2021
Here's a workspace (FME2020) that achieves what you need. You will need to populate/set the constant value for R1C1 in AttributeManager_3, text_line_data, currently set to "Constant value". I'm then using ass_num as the dataset fanout in the FeatureWriters. The first FeatureWriter writes text_line_data into the first line of the CSV file overwriting any existing files, then in the second FeatureWriter write the data out in the CSV format without overwriting the existing files and always writing the column headers
CSVWritingIn the attached zip are the output files the workspace created as well.
Hope this helps.
  • March 18, 2021
Hope this helps.
Thanks so much Tom. Works an absolute treat
  • March 23, 2021
Hope this helps.
Hi Tom
Trying to use the fanout csv that you showed me on another data set and theres something a bit wierd. I run the workbench and the text_line csv files are correctly created but the second featurewriter (FeatureWriter_4) doesnt seem to be writing or its writing first and then being overwritten by the text_line feature writer(FeatureWriter_3). If i run just the FeatureWriter_4 step then the data correctly appends to each individual file. Feature_Writer3 is before FeatureWriter_4 in the Transformer list.
I've compared the parameters on this new workbench to those from the one that works and I can't see any difference.
The Translation - Order Writers By: is set to Position in Workbench navigator.
Any ideas what else I can look for?
Thanks in advance
nampreetatsafe
Forum|alt.badge.img+13
left65 wrote:
Hi Tom
Thanks in advance
Hmm... that's odd. I tried @tomf​ 's workspace and it's performing like a charm for me. @left65​ , would you mind sharing the workspace where you are experiencing this issue? What version/build of FME are you using?
  • March 25, 2021
left65 wrote:
Hi Tom
Thanks in advance
Hi @nampreetatsafe​  I did make one minor change to the example from @tomf​ as my data has multiple lines per record. the Fanout_example is one that works (blue bookmark), the Misc_debtor_trans_new is the one thats not working quite right
  • March 25, 2021
left65 wrote:
Hi Tom
Thanks in advance
and heres the Fanout_example that does work
nampreetatsafe
left65 wrote:
Hi Tom
Thanks in advance
You might want to take advantage of the FeatureWriters ability to be placed in sequence in one stream. Not being familiar with the data you are using, I'm hoping this attached workspace I modified from your workspace gives you some ideas to build on.
Specifically, I think you need to include the text_line_data attribute in the AttributeKeeper as it contains content that you are writing out. You want to set the Aggregator to Use Attributes From One Feature so it doesn't lose the text_line_data:
If your workflow happens to end at the last FeatureWriter, you might consider replacing the FeatureWriter_4 in the screenshot above with a CSV Writer.
  • March 30, 2021
left65 wrote:
Hi Tom
Thanks in advance
Hi @nampreetatsafe​ that wont work as I the second feature writer needs to write a header row and multiple lines of data. I've attached the data that is coming out of TestFilter_4. it needs to write a file that looks like this
FORMAT TRANSACTION APPLICATION MIGRATION , STANDARD 1.0
DebtorSystem,AccountId,TransactionApplicationId,DebtorTransactionId,AppliedDebtorTransactionId,AppliedDate,AppliedAmount,Book_name
CAN,132,117,5001881,5000297,1996-07-12,-23,MISC_2021
CAN,132,219,5001882,5000796,1996-07-22,-11.5,MISC_2021
CAN,132,246,5000349,5001047,1996-08-06,-11.5,MISC_2021
CAN,132,633,5002906,5002393,1996-10-22,-23,MISC_2021
for each AccountID
  • March 30, 2021
left65 wrote:
Hi Tom
Thanks in advance
I couldnt work out how to attach multiple files so here is one of the output files that is correct but only if i run FeatureWriter_4 again, after the workbench has finished.
I did notice in the Translation log that the csv files from FeatureWriter_4 are being written before the txt files of FeatureWriter_3 - is there a parameter somewhere that sets the order????
I'm using FME Workbench 2020.1
daraghatsafe
left65 wrote:
Hi Tom
Thanks in advance
Hi @left65​ you could check out this on controlling the writer order https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Workbench/Workbench/Order-Writers-By.htm
  • April 6, 2021
left65 wrote:
Hi Tom
Thanks in advance
Hi @daraghatsafe​
The Order-Writers-By is set to "Position in Workbench Navigator" and the FeatureWriters are in the Navigator in the order I want to output them but as you can see from the attached log file the features are being written in a different sequence. Any other ideas?
