Help with reading blob from db3 file using FME
  • Apr 12, 2024 11:06 AM UTC
  • 405 views
manojse07
I am attaching a sample db3 file that I am using for a project. This db3 file contains many fields of blob type. The table, field of my interest are as below
Table Name: CURRENT_TAG
Field Name: _TAGOBJ_SUBSTATIONGID
select _TAGOBJ_SUBSTATIONGID from CURRENT_TAG where _TAGOBJ_GID = '145242397947723855';
This particular record in my application shows this value “151433541765593417”
But in db3 file it is actually stored as blob. How do I decode the blob as text? I tried to use online tools to convert this binary to text - it doesn’t work. Also, how do I know the data format that is stored as blob - is it either image, xml, json etc.?
crystalatsafe
Forum|alt.badge.img+32
Hi @manojse07
I tested this out and although I can’t quite tell if the decoded result is what you were looking for I was able to decode the blob format.
I first read in the table from that zip file with an SQLite reader.
Then I added a TextDecoder transformer.
I set the ‘encoding type’ to Base64 and the ‘string to decode’ as the _TAGOBJ_SUBSTATIONGID field.
You can try a different value for the ‘character encoding for binary data’ as each one will give a slightly different result.
I hope this works!
Crystal
manojse07
  • Apr 17, 2024 6:31 PM UTC
Thanks @cfitzpat for you answer. I did try the transformer you suggested and is still returning some garbage values. The actual value I am expecting is a GUID
Considering that the data type returned by sqlite reader for blob type is “binarybuffer” can we do something to achieve what is intended?
danminneyatsaf
Forum|alt.badge.img+13
@manojse07 What software are you viewing the .db3 file in?
I’ve checked the FME SQLite Reader parameters and it detects the data type as a Blob for your dataset so it should be reading in the values correctly.
I’ve cross-referenced reading the data in other database management programs (DBeaver) and a SQLite specific database reader (https://alpha.sqliteviewer.app/) and the results are consistent with what FME produces.
manojse07
  • Apr 20, 2024 2:24 AM UTC
@danminneyatsaf All the software you mentioned show the hex representation of the blob object. My problem statement is that I have to decode it to the text. If you can check my question - the value is actually a GUID that is encoded as a blob in the db3. So, when I read using FME I have to decode as a GUID.
